Whelp,
I decided to go ahead and create a build post for the old duke. I have a 2016 390 with just about 23,500 miles on it.
I'll try and keep things chronological.
Bike as it sits at the moment.
MIVV GP Exhaust setup
2nd Failed auto tensioner. Pin broke in the same spot as the last time.
I have a powder coating setup at home and decided to powder coat my valve cover.
This is the 2nd air box I have purchased that has cracked in the exact same spot.
The replacement setup: (Chimera Intake)
Installed the Gray Area KTM shift shaft support and an Ebay rod to eliminate pretty much all shift slope. The "Short" shifter is amazing.
Installed the Yamaha R6 rear shock and put in some slightly heavier front fork oil.
