1 - 3 of 3 Posts
Hello, I'm going to be replacing my Stator but after some research there seems to be 2 different gaskets for my 2013 390 Duke, I'm unsure on which to get any ideas anyone?
I am also unsure on if I have the updated case with the oil pathway in it or the original case.
Thank you.
Rectangle Font Eye glass accessory Circle Metal
Bicycle part Font Electric blue Drawing Fashion accessory
Administrator
The bottom 1 looks like the stator cover gasket, the other for the clutch cover, however, go to: ktmsparepartsfinder.com type in your VIN # and search under 'engine'.
This will give you the correct pn.
There have been some updations to the newer models with respect to the oil flow to the stator circuit owing to stator failures. It's wise to get your model and correct part for a hassle free fix.
Good luck.
1 - 3 of 3 Posts
