ENGINE
Design - Single-cylinder, 4-stroke, spark-ignition engine, liquid-cooled
Displacement - 690 cm³
Bore - 102 mm
Stroke - 84.5 mm
Performance - 50 kW (67 hp)
Starting aid - Electric starter, automatic decompressor
Transmission - 6-speed, claw shifted
Engine lubrication - Semi-dry-sump lubrication with 2 rotor pumps
Primary gear ratio -36:79
Secondary gear ratio -16:40
Cooling system - Liquid cooling system, continuous circulation of cooling liquid with water pump
Clutch - APTC™ Anti-hopping‑clutch / hydraulically operated
Ignition system -Contactless, controlled, fully electronic ignition system with digital ignition timing adjustment
Discussion Starter · #2 ·
CHASSIS
Frame - Tubular space frame made from chrome molybdenum steel, powder-coated
Fork - WP Suspension Up Side Down
Shock absorber - WP Suspension with Pro‑Lever linkage
Suspension travel front - 135 mm
Suspension travel rear - 135 mm
Brake system front - Disc brake with radially mounted four-piston brake caliper; floating brake disc
Brake system rear - Disc brake with single-piston brake caliper, floating
Brake discs - diameter front - 320 mm
Brake discs - diameter rear - 240 mm
Chain - 5/8 x 1/4” (520) X‑Ring
Steering head angle - 63.5°
Wheel base - 1,466±15 mm
Ground clearance (unloaded) - 192 mm
Seat height (unloaded) - 835 mm
Total fuel tank capacity approx. - 14 l
Unleaded premium fuel (95 RON)
Weight without fuel approx. - 149.5 kg
I've put a copy of this on the homepage, so people can find it easily there too. Thanks for posting this up!
