2015 390 duke
Does anyone know the thread pitch of the oil pressure sensor? I believe it's m10 but can't find any information about pitch. Any help or advice greatly appreciated 👍
2015 390 duke
Discussion Starter · #2 ·
As you can probably guess, I've got the dreaded low oil pressure warning issue that so many others have had. So I'm going to install an oil pressure gauge, that way I can stop worrying and fix the problem at my leisure.
2015 390 duke
Discussion Starter · #6 · (Edited)
Thanks for the reply Mik & Stevo, but it's the thread pitch I need so I can fit a t piece for the oil gauge ie. M10 x 1.5 or M10 x 1. Etc.. I've done everything that's been suggested in previous posts and I don't actually believe it's really low pressure so by fitting a mechanical gauge I'll know for definite.
KTM Duke 250 ABS 2017
Спасибо за ответ, Мик и Стево, но мне нужен шаг резьбы, чтобы я мог подогнать масломер по частям, т.е. M10 x 1,5 или M10 x 1. И т. д. Я сделал все, что было предложено в предыдущих сообщениях, и я на самом деле не верю, что это действительно низкое давление, поэтому, установив механический манометр, я буду знать наверняка.
[/ЦИТИРОВАТЬ]
М10 x 1.
