Tachometer constantly indicates zero speed. I also get a "battery low" indication. I measured battery voltage and indeed is low, engine strangles to turn on. Can the low battery voltage affects the tachometer indication ? Has anyone faced the same problem? Where is the vehicle speed sensor ?
Discussion Starter #2
Update. Checked the battery, it's steel good (voltage don't drop under 10V while cranking). Checked voltage with engine on I saw 12.5 to 12.6V max (should see over 13.5 at idle) I also saw the "JG_1.7.3" indication while cranking. Regulator or Magneto? What is your opinion?
On my Duke 200, I have similar issues.
Renewed the stator and indeed 1 of the coils was black/burned.
On my bike, though the speedometer goes back to 0 while riding every so often.
REV counter sill works fine though.
I think in most cases the battery needs replacement, my Li-Ion battery has been charged several times with a lead-acid battery charger and now starts giving me the JG_1.7.3 on the display as well.
I will be looking for a new battery next week and see if this solves the issue(s).
Must say though, after renewing the stator the speedometer is cutting off (returning to 0) a lot less?
Thank you. I contacted with the dealer and described the symptoms, his almost 100% certain its the regulator. He had faced similar cases. Stock regulator costs 100 USD , I found a used one in UK for 30. As for the speed sensor a brand new costs 30USD, not a big deal if the sensor is not the case and it is a wiring problem
My next step will be checking the rectifier/regulator with a multi-meter (allowing diode testing).
I will also check the new stator for any issues.
My problem is I live in a country with zero KTM parts supply, the nearest is Thailand but with the postal services not operating at the moment due to border closing I will not be able to order parts and get them here.
That's exactly what I an going to do before ordering. There is a nice video also at youtube "how to test a 3 phase regulator", for the diode test. I will update this post for the results
Discussion Starter #7
Update. Replaced the rectifier, nothing done, still "charging" at 12.3 volt with engine turned on. Have to use a charger after every ride. I ordered the stator. It will come to me at a month
Discussion Starter #8
I should have listened those youtubers who had upload videos with stator replacements
R/R was good, took it off to bench test it and put it back.
Been riding over 1,000 km since all good again.
Charging the battery at 7,000 RPM around 14.7V
Discussion Starter #10
Finally the Chinese stator that costs 40$ came and the bike looks good. Charging power 14V, tachometer ok!
