Hello all,
Recently the shell bearing died, took the crank and the con rod with it, i ordered a new crank assembly from my local ktm dealer and i figured out this morning that it was the wrong one, a decent inspection they are very similar the only difference that i noted was the keyway for the primary gear and sproket, is longer and not as deep as the old crankshaft, so i called a different shop and read them the part number and they informed me this part number is for 17-18 (mines a 16) now im wondering do i split the case again and pay the 25% restocking fee for the wrong part, or can i get a different key and make this work, i cant find any detailed information on what the changes were to the crankshaft between 16-17 and am wondering if this keyway was the only change, any insight would be very helpful thank you!
