1 - 11 of 11 Posts
Hi All
it is possible to install a 390 duke engine into the 200 duke chassis?
I understand many of the components are indeed shared across the range but I cant seem to find any technical details on this subject of
Ecu, forks, suspension, fuel tank, electronics, wheels/tyres?
If anyone has any experience in this subject then I would greatly appreciate your input.
Thanks for your time.
Reza
Hi All
Reza
Sell your D200 and buy a D390. Seriously.
agreed. for the cost you might as well just get the 390
unless you are trying to avoid some sort of legislation against the 390.
not possible, different engine mounting, unless you do some customisation to the engine mount, and u need a 390 ecu to make it work, also, the leg rest might obstruct the brake and gear lever. IMHO
I'm looking to do the same thing..They don't have the 390 here in Indonesia
They don't have the 390 here in Indonesia and the single one they sold was almost US$12,000 on the road.
From what I can see the chassis and bodywork suspension is the same in the two Dukes.. Seems the brakes are a bit bigger in the 390.
I have found a 390 motor for $1500 with 2K on it..
Different motor mounts are easy at any mod shop..
can anybody tell me what other issues I might have?
It will work,I have a 390 engine in a 125 frame ,all of this duke range use an identical frame,it's a perfect fit all mounts are the same not sure about ecu but the mechanics are perfect
Hi Scott, I'm interested by this swap project for my Duke 125 could you say me more please ?
Replacement parts complte engine (with gearbox and starter), ecu, exhaust, box filter, what more please ?
Hi I started with a duke 390 with a bent frame and brought a cheap 125 frame off ebay, I used all duke 390 parts ie clocks,ecu,loom,petrol tank,rear sprocket,are needed from the 390,also you need 390 exhaust I think,gearbox and starter also used from 390,the only 125 parts that can be used are,the frame,wheels,forks,fairing,seats, u basically need full engine from 390 with all engine components,all 390 electrical wiring including ecu,tank,and maybe brakes.
It's an easy swap if you have a bit of time good luck !
1 - 11 of 11 Posts
