1 - 20 of 23 Posts
Hi all,
My names Mitch, and I love my little 390! had it for a couple of months and use it to commute daily and longer rides on the weekend as well as a bit of track riding, taking it to my first drag night tomorrow. Started modifying it the day I took delivery, largely just cosmetic things, making it look a bit cleaner. Attached some pics of it a month or so back, couple more mods since but I'm yet to take some pics.
Thanks mate, the seat was well worth it. Much more comfortable than the stock item especially for long rides.
Discussion Starter · #9 ·
Thanks guys, yeah it's the ktm cowl, pricey part for wgat it is but worth it. Had a good night at the drags, best time was a 14.5 @ 150km/h. Should be able to get it down to a 14 flat if I work on my launches, pretty lack lustre atm!
Discussion Starter · #12 ·
the bars are stock, the mirrors i found on ebay, just type in motorcycle bar end mirrors and plenty will come up.
i found and bought these ones they look exaxctly the same but different colour. but i have no idea how to fit them
Pair Gold Color Universal Motorcycle Bar End Side Rear View Mirrors -in Side Mirrors & Accessories from Automobiles & Motorcycles on Aliexpress.com
Remove the current bar ends (if any, usually fastened with an allen key) and replace with these. There may be a threaded insert in the bar ends that you either need to remove, knock in, re use or re-thread. It's not hard.
MAKE SURE the throttle returns easily to idle after fitting and before you blast off!
isnt it a bad idea to take the bar weights off? i was hoping to mod them somehow to fit over the standard bar weights and
ok ive figured out how they work the only thing i cant figure out is how to remove the original threaded insert. any ideas?
the original threaded insert is Glued ... i tried to knock it in but it just wont move a micron .. so i plan to replace the whole handlebar ....
i was planning to put in an anti-vibration insert ...
1 - 20 of 23 Posts
