1 - 5 of 5 Posts
I have ktm 390 2017 model...every time I take my bike above 150 kmph ...the handle gets disbalance. Any suggestions why this issue is causing?
Tires out of balance, bad roads, skewed front axis, bad steering head bearings, lack of counterweights in the handlebars, the list is really long.
Thanks varroa, I will do wheel balancing and tyre replacement
A couple of things, either a worn out tire, improper tire pressure, tight triple clamp and or a just road camber. If this happens in a perfectly straight road every time, time to inspect your tires, tripe clamp slack and tire pressure. Good luck.
VJ
Do you have hand guards fitted? When l
had the KTM hand guards it made my 390 Duke less stable at higher speeds, as though it was verging on a tank slapper (although it never actually did it)
1 - 5 of 5 Posts
