1 - 3 of 3 Posts
I'm thinking of getting one but a little skarit . Also does it cost more to have the 390 duke serviced ?
Good question as one hear of so many issues with the 390... I have a 2018 390 Duke and did 8000km so far with no issues. The normal services you can easily do yourself. Have the shims checked every 15K by the dealer...
My 2017 apparently had a small piece of plastic in the engine that clogged the oil lines and starved the top end of the engine. Had the top end rebuilt at 2k miles, under warranty thankfully.
I don't think it's the build quality so much as the QA process personally. I'm not sure if things have improved, but I would definitely recommend that you make sure you keep up with the maintenance so you don't have issues if you need the warranty.
Reactions: vic.morales
1 - 3 of 3 Posts
