1 - 14 of 14 Posts
Does anyone know of any other rotors that fit the 390 apart from the extortionately priced ktm powerparts ones?
Moose Racing, cheapest Ive seen them is on Fleabay. There also some generic brand ones from Italy etc.
id advise changing the pads to good quality ones first and bleed your system, then see what you think Sintered EBC will cost about $70 to $80 for both ends over the counter.
EBC Brake Pad Codes
#Front - FA606HH
#Rear - FA213HH
dont forget stainless lines! new lines and a fresh bleed should give you much better feel. Agree with the pads comment. It may even be worth it to investigate replacing the whole cally.
steel lines, better pads.
both will improve brake feel but might change how easy it is to moderate your brakes.. might make them a bit grabbier.
check out Galfer, the OEM for Powerparts, i saw Breaking, looks more expensive then Galfer. I'm checking on the rear wave rotors to match my front.
I'm most interested in more pad options. Its hard to choose brake pads based on reviews because everyone has different criterias and expectations. I hate buying pads and not liking them and end up wasting them. Not like you can return them.
Category Maker Model cc Year Code Name Year Front Rear
Metal Resin Shoe Metal Resin Shoe
Street KTM Duke 125 125 11-13 VD-9068JL SD-9068 VD-953JL SD-953
Street KTM Duke 200 200 12-13 VD-9068JL SD-9068 VD-953JL SD-953
Street KTM Duke 390 390 13 VD-9068JL SD-9068 VD-953JL SD-953
Street KTM Duke 690 690 08-13 * VD-986JL * SD-986 VD-953JL SD-953
Street KTM Duke 690 ABS 690 12-13 * VD-262JL * SD-262 VD-953JL SD-953
Street KTM Duke R 690 690 10-13 * VD-986JL * SD-986 VD-953JL SD-953
Street KTM Super Duke 990 990 05-08 * VD-986JL * SD-986 VD-953JL SD-953
Street KTM Super Duke R 990 990 09-13 * VD-986JL * SD-986 VD-953JL SD-953
Guys...the 390's come with stainless braided lines that are just covered in black vinyl....
Just bleed the brakes to Dot 5.1 or Motul's RBF600 brake fluid and go for a Sintered Double H front brake pad...EBC, Brembo, SBS, Vesrah... You dont need sintered brake pad for the rear...just the front.
Stock rear brake is more than adequate....
1 - 14 of 14 Posts
