1 - 1 of 1 Posts
I broke the tool that's used to turn the engine over to TDC and remove the spark plug. I guess the slight angle I had it at because of the crash cage cause it to crack and expand a bit so it can't grip enough to turn the bolt to turn the engine. I finished the valve adjustment (and noticed I had the wrong shims) so when I get the right ones I need to do it again. Has anyone tried doing this with a different tool or found a way to get a replacement?
1 - 1 of 1 Posts
