1 - 3 of 3 Posts
So my chain seems aligned but when I'm sitting on the bike, the space between the chain and the plastic piece to the side gets larger and smaller as the chain turns.
Here's a video of what I mean.
chain.mp4
You can see that the side of the chain almost touches the plastic piece.
My chain looks straight, but I haven't used a chain alignment tool.
Is this because my alignment isn't correct? The tickmarks align perfectly on the swingarm. Bike has 2k on it, never been dropped.
Then I roll forward and ....
You shouldn't go by looks. Buy a wheel alignment tool, it should be relatively cheap. KTM powerparts sell one for very cheap.
Tickmarks could be offset off each other, and shouldn't be relied on for wheel alignment.
Wheel alignment won’t of itself cause the chain to move since it will maintain the alignment as it spins.
However unless you have a brand new chain running on perfectly clean sprockets then movement can be expected. Chain wear tends to be uneven so a single tight link will pull the chain at that point.
But movement in the front sprocket can also cause chain movement. I don’t think you can draw particular conclusions from your observations.
1 - 3 of 3 Posts
