Here you will get some answers:
I'm interested to hear your technique please?If you want to know how to easily clean the chain without kerosene or wd40 mess - ask.
Very well. This is a DID chain manufacturer method of cleaning the chain without any water washable chain cleaners. (Save your money) This method was recommended directly by DID that I got by email from their customer service department.I'm interested to hear your technique please?
Yes, 3 is optional, but I highly recommend it.Thanks for that John!
Are the goto number references correct? 3 is optional, not 4 or 5?
I hot wax (paraffin, plus beeswax and a dash of Teflon powder) my bicycle chains. They're dry and don't have anything sticky that attracts dust or dirt so they stay way cleaner and don't wear nearly as fast.
I currently own a Harley so don't have all this hassle but I'm thinking of getting a Duke/Adv 390 and I've been having a read of some of the threads in this forum. Naturally, the chain cleaning and lubing one is of interest. In particular, your journey from the 'monks' method using tried and tested gear oil to simply using the lubricant recommended by KTM in the owners manual has made me laugh! Is your next step to use the chain cleaner they recommend too? Hahaha! In the past I have used spray on chain cleaners and spray on wax similar to the KTM recommended Motorex products and found them to be quick & easy to use and very effective at keeping the chain clean and lubricated whilst minimising flinging off onto the rear wheel etc. Can't wait to see if you finally arrive at that conclusion in your next post!Quick review of Motorex Chain Lube Road wich is the recommended chain Lube for our bikes. Overall, I'm quite impressed. The lube when dries up becomes something like grease, so there's virtually no oil on the rear wheel. The chain is quiet and feels smooth, but it feels like that after every proper lube job with regular gear oil too. It would be interesting to see how easy it is to clean off after ~700km or so. I like the fact that it's white in color, so that I know when it becomes dirty and ready for cleaning. View attachment 55264
Thanks for your comment and a reminder that I need to finish my story.I currently own a Harley so don't have all this hassle but I'm thinking of getting a Duke/Adv 390 and I've been having a read of some of the threads in this forum. Naturally, the chain cleaning and lubing one is of interest. In particular, your journey from the 'monks' method using tried and tested gear oil to simply using the lubricant recommended by KTM in the owners manual has made me laugh! Is your next step to use the chain cleaner they recommend too? Hahaha! In the past I have used spray on chain cleaners and spray on wax similar to the KTM recommended Motorex products and found them to be quick & easy to use and very effective at keeping the chain clean and lubricated whilst minimising flinging off onto the rear wheel etc. Can't wait to see if you finally arrive at that conclusion in your next post!
Couldn't agree more. The exact method/products seem to matter less than the frequency. Thorough cleaning and lubing often are the key to good looking and longer lasting chain & sprockets.Thanks for your comment and a reminder that I need to finish my story.
As it turns out the Motorex Lube was simply excellent. It provided great lubrication of the chain for 700km (450mi) (I could theoretically ride on it for 1000km easily if not for the rain that washed away some of the lube); that's good news.
The bad news is it was extremely hard to clean using a regular simple green solution and I mean EXTREMELY hard. I had to sit there and soak clean with brush then resoak and then brush it some more for 3 times and still the motorex lube was stubbornly stuck in between the chain links. I had to use a little bit of kerosene on a toothbrush to finally kill it off. What a mess I created! Keep in mind that this doesn't detract from the quality of Motorex lube (or Motul C5 paste that was also hard to clean with simple green); the lube itself does exactly what it was supposed to do, so this is not about the lube at all. This is about the fact that I use a lighter duty degreaser than Motorex Cleaner to clean it.
In short, if you like to use commercial level lubes like Motorex for example, you have to buy commercial level of chain cleaners too. There's nothing wrong with that and they are as easy to use as applying gear oil and then cleaning with simple green degreaser.
So what's the difference you ask? Why should we choose one over the other? The answer lies in the cost and in the definition of the word "we".
My friend thinks that doing any chain maintenance is too messy and time consuming so he chose the simplest solution; he takes the bike to me and pays me to maintain his chain! Perfect solution if you ask me. You and many other people are ok with paying ~$30 for lube and matching chain cleaner several times a year (depends how much you ride). That's a fine solution too. Nothing wrong with that. It's certainly is simple. I prefer the gear oil for two reasons:
I love cleaning my chain frequently and I need an inexpensive way to do it. I don't mind cleaning overspray of oil from my rear wheel with kerosene when I clean the chain with simple green which is really easy on the x-rings btw. So the moral of the story for me is it doesn't matter how you clean your chain as long as you clean it every 400-600miles (~1000km). The costs associated are quite small and negligible for me, but for others cost of cleaning may be a bigger factor.
I use the recommended way of cleaning the chain by the chain manufacturer (D.I.D. in my case), NOT by a brand name that signed a marketing contract to promote a certain product line of cleaning/lubrication products, not that there's anything wrong with that. I absolutely love Motorex as a Brand and I always buy their motor oil, because it's actually the best for my bike in my opinion. I also am quite impressed with their chain lube and I will keep it in mind for the future, but I ride and clean the chain so frequently that following the maintenance suggestion of the actual chain manufacturer work out to be better for me.
