Hey guys and gals
Quick question..?
Does anyone else get a vibration through the clutch shifter/pedal?
I can feel fairly strong vibration in my foot when changing gears and I feel this is a new thing..
is it bad?
TIA
Sorry, but it is not clear to me what you mean?
Do you mean the gear shift peddle?
If so, why would that vibrate when only being managed when shifting gears?
Do you ride with your foot on the lever constantly?
yes, the gear shifting pedal 🙈🙈🙈🙈
no i dont ride with my foot on it
when i move my foot to change gears, i can feel heavy vibration in the pedal.
it is a very noticeable vibration, which led me to make this post
The linkage on my 16 was about to fall apart, there was WAY too much play in the joints, which cause the shifter throw to be far too long for my taste. Was so loose that it popped out of gear several times because I was not getting a full shift, so I replaced it with a normal heim joint linkage rod I had from some old Grom rearsets, now it is better than new. Was super loose but I do not recall any abnormal vibrations.
