1 - 9 of 9 Posts
hi
i have a 2017 duke, where is the crank position sensor located - i have engine fault codes which say its damaged
Where is the sensor located?
I couldn’t find it looking at parts fiche online
I think the Crank sensor and gear indicator sensor are the same part, they seem to run on the same loom
It’s behind the engine cover
That is correct. The part is listed as behind the stator coil. If you look at the parts list, it's no.22 on the 1st page of the engine parts list.
The Crank position sensor or the igniter sender circuit is on the top of the stator (inside the left side magneto cover)
VJ
1 - 9 of 9 Posts
