1 - 16 of 16 Posts
Hi,
I've seen the error "CAN ABS FAILURE" on my console. After multiple trips to the service center, they didn't know the root cause and recently they replaced the "abs modulator" under warranty. I haven't seen the error for a while and I saw it again today.
Is anyone familiar with this issue? The error only occurs when I'm braking. It's quite scary as the abs indicator light turns on indicating that abs is not functional.
Wheel speed sensors ? Wiring problem? Go back to the dealer and live it there till they find it.
This is just a little technical information. Maybe it helps you with the diagnosis and solving of the problem.
The CAN-BUS is used in the Duke for communication of many devices, i.e. ECU and others.
Physically the CAN-BUS are just two wires with high speed digital signals.
The service connector under the back seat is a connector to the CAN-Bus. It's also called OBD connector for On Board Diagnostics.
You can buy a relative cheap ELM327 adapter and use something like the Torque App to read information from the OBD which is similar but not equal to information from the CAN-Bus.
The Torque App also reads past OBD errors which might help with the diagnosis.
You need an adapter to be able to connect the ELM327 to the Duke connector. It's is described in this forum.
I guess that the error "CAN ABS FAILURE" indicates that there is something wrong with the CAN-Bus or any CAN-Bus connector, the ABS sensor electronics or mechanics or the ECU.
First I would check all electric ABS connections at the wheels. Maybe it's just a lose connector.
Wow Ede,
Thanks for this.
As a total electronics no-no this at least gives me an insight on the matter.
I love all the mechanic stuff but when electronics fail, to me, that 'is just swap out' for new :)
Wow Ede,
Thanks for this.
I know you like to "play" with your bike. You should have a look at OBD as a first step and CAN-Bus as a second.
It's amazing which information are available on OBD and CAN-Bus. I.e. individual wheel speed, brake pressure, temperatures and a lot more.
I build already a CAN-Bus reader based on an ESP32 and I have some ideas what to do with that info - secret project until now. ;)
Looking forward to meeting you ones the borders have opened and I am able to fly to BKK again.
Eager to learn more about this but, although this is all interesting info, I am more of a rider.
Next week head up to the north on my Duke 200 with new clutch plates/springs, stator and front brake pads.
Will be an interesting journey planned for 10 days during the monsoon.
I plan to visit some Khmer and other ruins along the way but first a couple of beers with some buddies in Savannaketh.
For my 390 Duke on Phuket I have some stuff lined up to modify, MotoMaster brake rotors, titanium bolts, Frando front calliper (MC already from Frando) and there is a Vizi-Tec brake light modulator on its way
Discussion Starter · #8 ·
Thank you @Ede . I don't have any equipment right now. I'll check with the service center guys for now. But, I'll definitely read more about this.
Discussion Starter · #9 ·
Hey @Ede ,
I visited the service center again. They replaced the wiring harness which didn't fix the issue. Yesterday they replaced the console display. They still don't know the root cause.
One odd thing was that as soon as the mechanic started the bike after replacing the console, the "CAN ABS FAILURE" error popped up again briefly. He mentioned that it could be because of low current supplied from the battery as he connected the OBD device for few minutes to read codes earlier. His justification was that the obd device would've consumed power from the battery and the available current was low when he started the bike. I feel that he was just covering it up to avoid any further investigation. and also the error doesn't say anything related low battery.
It's just weird that they've already replaced abs modulator, wiring harness and console display and still it occurred.
Hey @Ede ,
The CAN-BUS and controllers and OBD will use very little power.
How easy or difficult it is to diagnose the problem is probably directly related to KTM's software (in the bike and in their diagnostic tools).
In my experience bike mechanics are exactly that, mechanics. Few are good in electric and even fewer in electronic.
Personally I used the CAN-BUS only to read real time values and I never used it for diagnosis so unfortunately I don't have any better info for you.
Discussion Starter · #11 ·
Thanks @Ede , I'll escalate this issue and ask them to give a written acknowledgment regarding the error. You are correct, the mechanic doesn't look knowledgeable in electronics.
KTM Duke 250 ABS 2017
Hi @Ede . I also have a problem with the ABS, the official dealer is very far from me. Tell me which program you can view data from the ABS. I have an OBD Wi-Fi adapter but I can't find a program to connect to the ABS.
Hey @Ede ,
It's real man. Today my battery was dead. And when I tried starting the bike the same error popped up for the first time.. maybe battery is the cause. Try changing a new one.
Sorry for the late reply.
I don't think you will be able to see any ABS data with an OBD reader.
I built myself a CAN-bus Logger with an ESP32 which logs all CAN-bus traffic, not just OBD (which is only a small part, if it exist at all).
If you google "can bus logger" you will find devices for sale, and maybe also instructions how to build one.
But even if you have such a logger then you have to analyze the data which is a lot of work.
I did that with a program/database which I wrote myself. It works for me but it is no complete software which anybody else could use like it is
Sorry for no better news.
Hi @Ede . I am using the program Car Scanner. With her help it turned out to look at the errors in the engine block and dashboard. The program sees the ABS block, but it does not respond to standard requests, so you cannot see the errors.
Hey @Ede ,
bro,any updates
1 - 16 of 16 Posts
