Thank you for your prompt reply! I guess it should then be this guy
I guess I'll have to remove the main seat, at least, in order to access it. Again, if anyone already did it, please share your advices. I thank you in advance.
The reason I'm doing this "research" is because recently my 390 is behaving oddly while warming up (before reaching the 7/8 bars of temp in the display) with the engine doing some hiccups/misfiring during gentle accelerations. If I push it a bit harder I'd say I cant feel this behavior, and after reaching the working temperature it performs/behaves as expected, no hiccups, just plain and smooth.
Spark plug (NGK Iridium) is new (less than 5k km), air filter, the same, so I'm excluding them as potential culprits. Fuel pressure, stator, ignition coil, related issues should (?) keep popping up even after functioning temperature is achieved, I guess.
Valve clearance is to be checked in the coming weeks (less than 1k km) to the next service, but I'd say it is not related to this as well.. not completely sure though....
For now, I'd like to reach that temp sensor, hopefully it has something to be cleaned...
