Looks very different now. Quite clean. Your highway pegs serve as a frame slider, too
How do they fit? Any extra slop you don't get with OEM?Nothing special. Some China brand off amazon short lever because I didn't like the long stock lever.
MZS Black Motorcycle Brake Clutch Levers Short Adjustable CNC ME-3939
Thanks .. The slop I was referring to would be up/down movement in the perch.They fit jand are just as strong as oem quality. The feel is personal preference though. There is a rounder lever whereas this model is square.
If you are referring to slop as in pulling the lever 2mm or so and there is no engagement then that is just an adjustment you have to make with any lever to whatever comfort level you like.
Also .. No clearance issues with the brake lever contacting the throttle housing? About to pull the trigger. ThanksThey fit jand are just as strong as oem quality. The feel is personal preference though. There is a rounder lever whereas this model is square.
