Duke 390 22’ Gear Lever Oil Leak
168 Views 4 Replies 5 Participants Last post by  DukeofSeven
Hello, I have an oil leak issue in a brand new duke. It is leaking a little oil from the gear lever. Why does this happens?
Motor vehicle Automotive tire Automotive exterior Automotive design Carbon
See less See more
1 - 5 of 5 Posts
The black rubber oil seal has gone bad, change it and the leak will stop
If its new its covered by KTM for two years. Pop down to a dealer and book it in for a warranty job. Chances are there has been a burr or swarf on the gear shaft which has damaged the bearing seal.
Is it leaking or have you just noticed it is oily/greasy?
Could this be that this is installing grease?
Try to wipe it dry on the outside with some paper tissue and see if it stays dry or leaks.
Why do I always have the urge to say things like...
"Yep, that's a bleepin' dead alien alright."
1 - 5 of 5 Posts
