1 - 9 of 9 Posts
I want to tune my 2013 duke 390 with external ecu Haltech sprint 500. can someone tell me whether stock ignition coil has a built-in ignition module or its ignition module is integrated in ecu. where can get coupler part no for constructing a complete new wiring harness for haltech platinum sprint 500.
The ignition coil sits under the right-hand side of the tank.
Must be an external coil, not integrated into the OEM ECU.
Never heard of a Haltech sprint 500.
Will look that up, interesting, thanks and good luck.
i know ignition coil is external but ignition module is something which controls ground signal to coil. i found out that ignition module is built inside ecu.
Discussion Starter #8
I'm interested to see your results, are you replacing the factory harness with a Haltech harness that you have to build?
Yes i will replace harness ,ecu and will be using GM ls2 ignition coil because they have a built in ignition module
1 - 9 of 9 Posts
