Youtube Video
SO basically, having this problem for 3 months. At the beginning when driving "intense" and with high revs, the engine will turn off, if i continue throttling, and it would do a stupid amount of POPS and BANGS (propably due to the not burned fuel). The more I continued driving with this issue, the earlier (with less and less RPM/throttle) the engine turns off. Coming to now, where you can barely drive with 0.1% of throttle, if more, the engine just dies. So luckily i found this guy having the excact same issue i can say.
The guy said in the comments, it turned out to be the valves being to tight, especially the exhaust ones, and a valve adjustment with proper sized shims fixxed the problem.
My question now:
1.Do I have ONLY have to adjust the SHIMS, or do i have to check the valves theirselves too?
2. I d like to know WHY such a problem occured and how it can be prevented.
My question now:
