1 - 20 of 23 Posts
I need help getting this piece as it seems to have felt off. I took a look at the parts diagram and can’t identify it. It’s like a bolt that connects to the rear brake. My foot brake doesn’t work without it. Any help would be greatly appreciated.
I doubt you can but that separately as it’s part of the rear master cylinder. You could probably make one but you need the dimensions.
Thanks. You’re probably right. Is this a difficult job? Could I do it myself perhaps? Btw I used your video to install the usb charger. Great content.
Not 100% sure what 'bolt' you mean, is it not the retaining pin (+washer + split pin) 17, 18, 19?
Simple enough job if you use the part from the new master cylinder. However I’d have to question how this part could have come out as normally you’d need to remove the brake pedal to get enough travel to remove it. Perhaps something broke or perhaps something was really badly adjusted.
Discussion Starter · #8 ·
I'm wondering the same thing. I noticed it Saturday night, I went out to the city and was wearing different shoes than I normally would like my bike with. I was riding and used the front and rear breaks on the road and felt the foot brake loose. Later I stopped and noticed that was gone.
Discussion Starter · #9 ·
Also, I did another odd thing I did, I was going to an ATM and rode my bike up a sidewalk. I'm not sure what it was for certain.
Discussion Starter · #10 ·
Maybe I hit the spring with my shoes and it made it loose and it came off. Not sure
Discussion Starter · #11 ·
Anyhow, I should order the rear master cylinder? KTM 93013060000 - Rear master cylinder : KTM World
No. You have lost the master cylinder push rod. These are normally held into the master cylinder with a circlip. But you also have to remove the brake arm first. So it’s a mystery how the circlip came out, the rod unscrewed and still had clearance to fall out.
I’d suggest just buying a used master cylinder and using it for parts.
Discussion Starter · #16 ·
I'm going to order a master cylinder, I hope it comes with all the parts I need. It's actually cheaper to buy it new thwn used based on what I've seen on ebay vs KTM parts dealers.
Discussion Starter · #17 ·
I have contacted multiple dealers and even KTM themselves here in U.S. nobody has this part and they said it could take months to get.
Discussion Starter · #20 ·
I bought a used master cylinder, will be arriving tomorrow. I can't just take the push rod off the cylinder that comes in and put it in my bike? I'm not very familiar with the brake arm and don't want to pay someone to do it.
1 - 20 of 23 Posts
