1 - 13 of 13 Posts
Hi all,
Does yall's front disc brake feel the same as mine? jerky and unsettling? Even when my ABS is completely off It feels the same. I'm not complaining about the efficiency though, stops just fine and in time, but in a very struggle some pattern. Any other bike brakes very smoothly on the front without any jerks.
PS: My bike crashed twice, impact directly on the front tyre which burst instantly and 2nd time, suffered sides way damage. But the service centre guys confirmed there is no bend in forks or any wheel damage. I'll get it checked again if necessary.
Help
Was the same feeling of your front brake there before your crashes?
Good question, I particularly don't remember, but it's very prominent now. Does your duke brake smoothly at the front?
It's time for a service anyway, shall get it checked.
Both my Dukes, 200 with OEM 280mm front disk (no ABS) and the 390 with a 300mm floating EBC rotor (ABS) brake perfectly as should.
Both bikes run EBC HH Sintered brake pads front and rear (neither has ever been in an accident).
My ‘15 390 with the 300mm OEM front and ENC sintered pads has a pulse that I cannot resolve. I’ve scrubbed both sides of the disc with scotchbrite pads, brass wire wheels, tons of brake cleaner, 220 grit wet sandpaper, replaced the pads, bled the line repeatedly, can’t solve it. Considering just upgrading to the 330mm disc and hopefully putting it to bed once and for all.
Put a straight edge across the disc in a few places to check if it is warped. If you have an ABS model check the ring and sensor for damage - also unbolt sensor and check if problem goes away.
2020 KTM Duke 390
likely a warped disc if its pulsing as you slow, More noticable the slower you go. Usually caused by excessive heat on one part of the disc. I stunt mine and so far it hasnt happened but my 675's both warp discs atleast once a year. You can test for it with a runout meter while the front wheel off the ground and spinning.
Discussion Starter #10
Yes, thank you. I'm sure that is the problem, I even told my service centre guys it could be that. They don't seem to spot the issue and finished the service. On the first day, it was negligible, but the same issue persists right after the 2nd day and the full handlebar and hands shake whenever I apply front brake!
Discussion Starter #11
I think so too! But KTM service centre ruled it out saying the disc is fine. It's very annoying and unable to find the fix.
This may or may not effect your issue but whenever you crash and have impact on the front always loosen your forks and bars as the forks can twist quite easily in any crash and once you're relatively sure it's all in alignment (visual only if not at a shop) tighten back to torque specs.
Myself Im definitely not satisfied with the 390 stock brakes and the wave rotor and sintered pads is on the list of items to do
2020 KTM Duke 390
If they did check it ask them what the runout amount was? If they cant answer that, ask them to put a run out gauge on the disc and recheck it against the accepted limit in the manual and to provide you with those figures.
1 - 13 of 13 Posts
