Hi all, new to the forum but came across this thread and thought I would pass on my set-up.
I have a 2017 390 Duke which I use for commuting, touring and squirting in the hills.
With the stock 15/45,
1. Commuting (20-60 kmph) was painful as I had to constantly change gears if my speed varied by 10-15 kmph. The bike was also quite jerky at the initial throttle opening and closing as a result of the gearing.
2. Touring (80-120 kmph) was painful as I had the bike sitting between 9-11 rpm which is not good for the motor on long stretches or my body as the thing would vibrate a lot.
3. Squirting was painful as the decel from high rpm (8+) would unsettle the chassis too much for my liking but if you got a stretch that required 4th it was the sweet-spot!
So, after experimenting (playing with gearing is both cheap and easy) I settled on 16/42. I can commute in 3rd at any speed other than from a stop. I can tour all day at 110 kmph sitting at 6 rpm flat (no harm to engine or overtly vibrating) and squirting is fun in 3rd - 5th which covers the useable speed range up in the hills.
Other than stunting, I cannot understand why some folks go even shorter gearing than stock. At 16/42, the bike has more than enough punch for street riding with the only qualification being overtaking in 6th. You need to plan ahead and then drop it too fifth for that quick pass but that's common for a lot of bikes under 1000cc!
To give context to my comments, I also own a Ducati 999S (2005 - road bike) and a Gixer 600 (2004 - track bike). I bought the 390 for a commuter but honestly, I find myself riding it more often than not now, it's just a blast in any situation and it truly does them all with the right set-up.
I sorted the gearing and suspension (Andriani fork inners & Yamaha R6 shock swap) and a floating disc at the front (Bikemaster) with pads to suit.
