1 - 4 of 4 Posts
I just found a 390 adventure one year used for just 5000 euros, so I bought it. Great bike, tried some fire roads also reminded me my old klx300, only a little bit... stronger and heavier
Some times makes a stall like someone unplugs the wire for a second, or like a fuel cut for a second. Checked the plug wiring, is not loose. Read some forums said they fixed this (at duke) by cleaning the throttle and the fuel filters.
Bike is still on warranty.
Any help?
Congrats, you'll miss the 200 ;)
Is it the same system as on the other 390s with the side stand switch?
Perhaps this is where your issue lays?
Thank you for your answer, fortunately that wasn't the issue. Thank God it was just bad fuel that maybe had affected the injector. I just added some injector cleaner and 100 Ron fuel and after a couple of miles no more engine cut.
I will definitely miss the agility and sharp cornering of my little duke. Fortunately it will go to a good friend of mine, so it will stay close.
1 - 4 of 4 Posts
