I'm thinking about replacing stock cartridges in a 2019 Duke 390 with Andreani inserts.
Duke service manual describes for leg disassembly as fairly simple:
1. Unscrew the top cap
2. Drain the oil
3. Remove the bottom screw under the fork leg
4. Slide the entire cartridge out
The installation manual for the 105/kt7e describes more steps
2. Split the internals to remove the spring (this requires a special tool and, from what I've read, heating up some red loctite)
3. Remove the top part of the internals and the spring
4. Drain the oil
5. Remove the bottom screw under the fork leg
6. Slide the bottom part of the internals out
Both instructions describe installation as more or less the reverse of disassembly.
Why would I need to separate the fork internals and install them in steps? It looks like the Andreani inserts come as a pre-assembled cartridge unit, with the spring installed, and the post-2017 Dukes have cartridges that should come out as a unit as well..
Or are these Andreani instructions for older models (pre-2017), with damper rod stock internals? I've checked the manual for 105/kt2e (for the older Duke 390) and it has the same steps and pictures.
2. Drain the oil
4. Drain the oil
