1 - 1 of 1 Posts
About a month ago I set up the shift pedal in the lowest position to suit my needs
There began the problem with the gear indicator sensor, which consist in that it generally does not show the gear engaged or the neutral indicator
I tried different settings for the shift pedal, but I didn't see any changes in the sensor
A week ago, I realized that the problem with the indicator only occurs when the engine is hot, ie. at operating temperature
All information will be welcome
Regards
1 - 1 of 1 Posts
