1 - 9 of 9 Posts
The 390 Duke has everything that distinguishes a genuine KTM - from the high-quality chassis components to the multi-function cockpit, which even keeps you up to date with fuel consumption and remaining range. The extensive KTM PowerParts range gives you the option of adding your own individual style.
If you're removing the front headlight - be careful not to lose the washers shown with the arrow. They're easily dropped. To put them back on is a bit tricky. For the plastic inserts - to remove them push the centre plug all the way in with a small screwdriver (no turning needed). To reinsert them remove the plug and push it in from the outside part way, insert the insert into the hole and then push the centre plug flush.
http://www.dropbox.com/s/mr4na6cdhw45ild/2013-12-14 18.41.19.jpg
Electrical Accessories Power Point is wired in
In the front headlight cowl there is a pre-wired electrical accessory point. It's switched on with the ignition switch. I don't know the load rating but suspect it's probably 10A max.
The pic below shows the "accessory" wire tag and the two connectors (with my Singapore ERP unit wired in).
https://www.dropbox.com/s/sixc3esrotlr3au/2013-12-14 18.38.31.jpg
The plastics (black and clear) scratch super easy. I'm going to get some 'screen protector' for a smart phone and put it over the clear part at least.
This isn't the nicest instrument cluster I have ever seen. I think KTM could have sprung for a nicer screen. I'm sure it does everything it needs to, but other bikes I've been looking into definitely win out on this point.
1 - 9 of 9 Posts
