I need some advice again.
My KTM 390 duke [2018 model] has started new problem, “engine stalling”.
It started giving this trouble at 13000 km. [now its 14500, still having it]
While acceleration, while deceleration, while constant speed, while off throttle, while full throttle, while in gear[any] and while in neutral.
There is no pattern basically, except for the fact it happens within first 20 min or so. After that, bike would go flying for hundreds of km giving that full experience of hair-raising acceleration and dashing through corners without any sign of engine trouble.
Red “engine-sign” appears on and off, at times.
Bike condition
Interesting findings
Feedback from service station
My second option is to buy a new ECU and try, as I feel the fault must be in the electronic part.
Can I just throw the old ECU, put the new one and just “ride”?
Or will I need the service guy and his scanner thing to fix new ECU?
Please help me on this. You guys must be having lot more experience.
- Nature of the problem
Bike condition
- Odometer 14500km
- Proper engine oil level, new oil filters, oil screeners good, new fuel filter, new air filter, new spark plug, throttle body cleaned, fuel injector cleaned, battery good [goes up to 14.3V] fuel tank cleaned and dried, OBD clear, ECU error codes cleared at service station. [Basically, I have attempted every possible end that I could figure out] did everything to fix the problem but problem stays on continuously
- Trouble comes up in both cold morning or hot noon. [in my country there are no big summer winter difference, its around 30C these days.
- Bike was reset-or error memory cleared by the service guy once and suddenly the problem was gone for a day, where I rode it back home 60 km. next day, **** happened again.
- When engine stops while riding, hitting start button does not start the engine. I hear it keeps cranking but would not start, regardless of how many times I would try.
- Instead, if I turn the key off, wait 5 seconds turn on again, wait till the TFT display boosts up and touch the start button, bike starts up nicely, and I can ride till it stops again, to repeat the process.
- I found that even if I keep the key position unchanged and use engine run-off switch on handlebar to cut off, wait then switch on after the bike stalls, it starts when the starter button is touched.
- Even manual push start won’t work when the engine cuts off, but switching off the key [or run-off] and coming back does the job.
- What I do now is be obedient, to pull the clutch as soon the engine goes off, so the bike still is moving and turn run-off switch off. Then switch on and push starter to get the engine back and continue riding.
- They are clueless. Keeps telling me they will figure it out.
- What I wanted them to do was reset my ECU to factory setting [like mobile phones can be reset] but I don’t know if they understand.
