1 - 16 of 16 Posts
Hi,
Can someone link me to a website that sells this exact model of bar end mirrors? I searched and searched but i cannot find them :'(. There are similair models on ebay, but i want the exact model as the picture below.
TIA !
imgur.com/a/JHZuJLH
Thanks again
Hey there! So first off, there is no bard end mirror that fits perfect without some extra parts. First off head over to https://www.rhinomoto.com/https:/www.rhinomoto.com/rc390-mirror-mounts/ and pick those new bar end up. They have a cut out for bar end mirrors so you won't fun into any throttle issues. They are made to fit CRG mirrors but other on eBay may fit as well. hope this helps!
Discussion Starter #5 (Edited)
Guys, so after a lot of research I was able to find these mirrors that I posted before. Apparently they are KTM power parts, but according to the ktm website they at not compatible on the 390.
"Handlebar end mirror set Ref 00010000290"
"Handlebar end mirror Ref: 64112940000"
But on Instagram I so a lot of images of the 390 with the same mirrors. Any one knows how I can install them on the 390 ?
TIA
Handlebar incompatibility on the 390 compared to other KTMs typically refers to the threaded plug in the end of the 390 handlebars. Changing the fitting system of the mirrors can solve the issue.
Have you got a link for the parts i need?
TIA
Your local hardware shop should do, but remember spacers etc as usual if you need clearance for the throttle tube. You may be able to reuse your existing handlebar weight bolt.
390 uses a bolt to clamp down into the threaded insert. Standard bars including other KTMs use an expanding insert.
Compare the catalogue images for the Powerparts orange anodised bar end caps for 390 compared to other KTMs and you will see what I mean.
Discussion Starter #9
but apart from buying the ktm 790's mirrors, should i need to buy something else?, I'm asking because i dont wish to buy 100euro mirrors for nothing. At least i would want to know before hand what i will be expecting and what will i be needing before hand.
Do you have a link to what you intend to buy, including any fixings that comes with it?
Discussion Starter #11
That is what im asking.. haha. I will buying the ktm duke 790 handlebar mirrors, but it says not compatible with the 390. Im asking here to see what i will need to make them compatible.
These are the 790 Powerparts mirrows as stated in my previous reply ?on the 790 they fit downwards tried that on my 390 but as the bike is smaller you catch your kness in full lock.
Fitting is simple just use a 6mm cap head screwed straight into the bar end which is all ready threaded ? IMG_20190203_195949.jpg
Fitting is simple just use a 6mm cap head screwed straight into the bar end which is all ready threaded ? View attachment 48783
You will even have the 6mm bolt from the bar end weights so that should be the easiest option.
Hi Gordeh,
Technically, you do need spacers for the throttle side if you are just using the mirror with no other attachments. I am stuck in the predicament that I have to purchase washers or find a spacer that works with the bar-end mirrors.
Anyone have a link to any good spacers online that will fill the gap these bar-end mirrors KTM Duke 790 Bar-End Mirrors
Kindly,
Danny
Hi mate
I m also buying 790 end bar mirrors for mu 390 duke.
Did you fit them? Needed some axtra parts?
1 - 16 of 16 Posts
