1 - 11 of 11 Posts
Good morning, I got my Duke this weekend and have used it to get to work(61Km so far).
When I got to work this morning the Hazard light was on? Any advice?
Query
Hi
Was the Hazard light on continuously or only at the start?
Asking as it remains on for 2 to 4 mins when you start the bike and then goes off.
Else it comes on when the fuel level is low...
As said before hasard light comes on " normal " when the fuel is low , when the kick stand is down ( but then you should be able to put the bike in gear without stalling ) and a short while after setting off the time for the system to check the ABS function .
Try the reset as mentioned above , remove negative lead of the battery and replace .
If the warning light persists take it to the dealer asap
Welcome to the forum which carries a search option up in the header.
Type in any key-words of a subject you are interested in and if there have been any posts, these will show up.
Just bought a Duke 390 and just joined the forum.
- I noticed the warning light is on, on the dash. What is the 15 minute reset??
That you. So if I am getting a lit warning light, are you saying the way to fix that is out it on a paddock stand and let it run for 15 mins, than shut it off and that should calibrate the ECU, like automagically?
Not really, it says that this procedure resets the ECU to its default settings.
I never mentioned a paddock stand and preformed this procedure sitting on the bike.
Check the thread as I believe for the second-Gen bikes the procedure is 10 or 11 minutes.
If this involves a wrong readout that has triggered a light to come up, yes this procedure will correct this.
If this warning is not due to low fuel, you might want to buy a KTM Duke 390 OBDII adapter and a bluetooth adapter, then you'll be able to read in the error codes using an app like Torque. I've done it, and this setup works well.
Something like this:
Combined with your choice of a bluetooth OBDII adapter, like this:
VEEPEAK is the one that I have, it just works without issues for $13.
1 - 11 of 11 Posts
