The electronic engine management system always gets optimum performance out of the ingenious LC4 engine. More advanced technology than ever is taken advantage of in 2012 for this purpose: Twin ignition with individual mapping for each spark plug ensures that the mixture is always burned effectively, irrespective of load and engine speed. And then genuine ride-by-wire, in other words electronically controlled throttle valve actuation without any mechanical linkage. So that the electronics always apply the power as perfectly and therefore smoothly as possible, above all on transition from throttle closed to throttle open. How good does that feel? Simply indescribable. So check it out!
Thanks to the mechanical and electrical refinements, the new 690 Duke uses even less fuel than ever. Even though the last Duke had already won international consumption comparison test rides with ease. Duke riding will therefore be even more economical and environmentally friendly, while remaining unashamedly fleet-footed, sporty and dynamic.
