1 - 4 of 4 Posts
Here's the official list of the 2014 KTM RC 390 Specifications/Technical Details :D
_____________________________
Engine
  • Design: 1-cylinder 4-stroke engine, water-cooled
  • Displacement: 373.2 cm³
  • Bore: 89 mm
  • Stroke: 60 mm
  • Performance: 32 kW (43 hp)
  • Starting aid: Electric starter
  • Transmission: 6 speed, claw shifted
  • Engine lubrication: Forced oil lubrication with 2 Eaton pumps
  • Primary gear ratio: 30:80
  • Secondary gear ratio: 15:45
  • Cooling system: Liquid cooling system, continuous circulation of cooling liquid with water pump
  • Clutch: Wet multi-disc clutch / mechanically operated
  • Ignition system: Contactless, controlled, fully electronic ignition system with digital ignition timing adjustment
Chassis
  • Frame: Tubular space frame made from steel, powder-coated
  • Fork: WP Suspension Up Side Down
  • Shock absorber: WP Monoshock
  • Suspension travel front: 125 mm
  • Suspension travel rear: 150 mm
  • Brake system Front: Disc brake with four-pot brake caliper
  • Brake system Rear: Disc brake with one-pot brake caliper, floating brake discs
  • Brake discs - diameter Front: 300 mm
  • Brake discs - diameter Rear: 230 mm
  • Chain: 5/8 x 1/4” X‑Ring
  • Steering head angle: 66.5°
  • Wheel base: 1,340±15 mm
  • Ground clearance (unloaded): 178.5 mm
  • Seat height (unloaded): 820 mm
  • Total fuel tank capacity approx: 10 Liters Unleaded premium fuel (95 RON)
  • Weight without fuel approx: 147 kg
1 - 4 of 4 Posts
