Hello yesterday and today i was out riding then i got a low oil pressure warning馃檭 so i tried changing the oil but still no luck:( What should i do? Its a 2017 390 duke. Thanks for any advice in advance!
Generally when you get an oil pressure issue you must turn off engine instantly and never turn on untill you find out what is the problem. Oil pressure sensor failure possible at these engine but I have seen also oil pump failure or few oil in the oil tank.
