Does this look normal to you?
51075
I’m told the white block is where the alarm will go (fitting at the weekend) and that the purple wire is it’s aerial. The brown wires shoved into the white block baffle me. I hear the small white connector is for KTM’s charger and that it doesn’t come with any sort of cover.
Is this normal?!?!
Yep. Normal. When you fit the alarm and it’s mounting bracket, you will remove the tape around the white connector and pull the half out that has the brown loop of wire. Save it.
The alarm is nice. Plug and play with several parameters that you can program in with the remote. Default was fine for me. The arming/armed light is built into the dash which is nice.
