Today I build my Mini KTM OBD2 Bluetooth Adapter
After I bought the parts I thought: Why should I use that big connector? So I disassembled the ELM327, removed the board, soldered it together, put some hot glue over the contacts and covered it with heat shrink. It works fine.
ELM327 OBD2 - Bluetooth
https://www.banggood.com/HHOBD-ELM3...to-CAN-BUS-Scanner-Tool-Android-p-913030.html
KTM connector
https://www.ebay.com/itm/HM-6-way-connector-MALE-set-with-pins-seals-Sumitomo-Sealed/282054195957
The pictures should show all the details. The big connector is not needed, I just show it to compare the size.
KTM connector
