Duke 390. Surprising huh…..
Powder-coated ? Or kind of Plastic-sprayed ? (Would imagine Powder-coating could be quite brittle). Plastic type spraying as found on high quality mesh fencing would be every but as hardy - but a little more supple.
And of course Powder-coating requires alot of heat when its finally baked on. Not sure if that might either weaken or harden the spring material. Affecting safety and spring rates.
Just some thoughts........
Good Luck !!
Are you sure the spring rate is correct? I would consider riding with it first to be sure before powder coating.
Also, I like the fact my spring isn't white on my bike. You want yours to look like the original? Or to maintain an orange/white theme?
Discussion Starter · #4 · (Edited)
Good Luck !!
I had a chat with Mike (the owner of shock factory)
He says powder coating will not effect the tempering of the spring.
When I ordered the shock I gave my weight with riding kit on so spring rate should be correct.
I don't like the red spring it looks out of place and yes I like the orange / white theme
Looks good!
Hope spring rate is on point
Reactions: Drzjohn
