There is a 6 pin conne tor behind the battery covered with a plastic plug. The obd2 cable attaches to it.where you connect this adapter ?
Cannot remember if it was this or the Grom, but I could have sworn the plug was red on one or both. LOLOh ok thats why there is covered plug, thanks for the info!
Could you please share those PIDs?Yes, you'll need this:
KTM OBD2 Diagnostic Plug Adaptor (TUNE ECU, OBD2 Reader) - Lonelec
Used with the amazing free TuneECU software or any OBD2 hardware/software. We sell interfaces separately if required.www.lonelec.com
And a ELM327 BT OBDII reader like THIS, and the Torque Pro app. Add a couple of custom PID's to the torque app & you can see things like RPM, Gear, AFR from the O2 sensor & what the computer commands, and TPS, directly on your phone. Also allows you to read & reset fault codes.
Disregard the title, only works on 1st Gen, post #4 here.Could you please share those PIDs?
HAHA! Beat me to it!!!!!![]()
Torque Pro AFR PID 2018 Duke 390
Does anyone know the formula for adding AFR PID for the 2018 Duke 390 in the Torque Pro app? I've searched and can't find it, even outside of this forum. Thanks. Sent from my P00I using Tapatalkwww.ktmduke390forum.com
