1 - 5 of 5 Posts
Make sure it's not actually coming from the oil filter cover. My bike had 50 miles on it when it started leaking oil. Turned out the oil filter cover o-ring had gotten pinched at the factory or dealer. Dealer sent me a new one. Mine appeared to be leaking from the same spot as yours since it leaned on the side stand until I pulled the lower cowling off and traced it back to the filter cover. Not sure if it helps you or not.
That's what I thought at first. I quoted it clean and watched it leak from that spot. I can't find an oil trail from the filter cover.
Same problem, how was it resolved?
It's a defect from the factory. They replaced it with a new style engine case.
Sent from my Pixel 5 using Tapatalk
1 - 5 of 5 Posts
