1 - 18 of 18 Posts
Or replace/place the o-ring: J770024015 24X2,5
I wouldn't suggest the oil leak product. That product is for old engines with piston oil ring leak and very small leaks. You should replace the o ring.
Thank you for suggesting
I did have ktm duke 390 few weeks ago. l had my duke for 13 months I never put oil in the time I had it.it done 4500 miles without putting oil in the engine. The only time I put oil in the engine is when I done a oil change which you have to do every year or miles you do ?The engine are reliable and never burn oil.Maybe your engine needs piston rings to burn oil or something else like a oil leak into your exhaust which can lose oil though your exhaust or air filter can cause this problem I say to you do an experiment on it thank you
1 - 18 of 18 Posts
