1 - 20 of 20 Posts
Does anyone have any knowledge of the rapidbike exclusive? I see it is a bit cheaper. Does it still perform the same as the evo/racing? Any other input on the performance of rapidbike products?
Yes it works , only difference is it cannot be reconfigured . It will only fit a KTM 390 , that's the exclusive bit . Very happy with mine no problems experienced apart from needing smaller hands to make all the connections . When I eventually sell my bike on the new owner will benefit .
Exclusive as noted above means you can’t reprogram it for a different bike but it works just the same aside from that. Evo and racing are very different units.
Are there real world benefits apart from making the fuel mixture a bit richer? I bought the EVO for my Ducati and was very disappointed (for the money spent). I'd love a few more horses out of the 390...
For a full cat delete and slip on, will the evo be fine? I noticed the racing has ignition while evo does not.
Do you have any other exhaust modifications or anything?
Yes. Racing is more aimed for a track bike which is why it comes with options for launch control, quick shifter etc.
Discussion Starter #12
Yes mine is a 2018 model and yes I have lost my cat .
Cool so we have the same thing. Is there any issues at all? Loss of power, bike running too lean?
Discussion Starter #13
Also if I read right, there is a 2 pin voltage plug. Where did you find that one at?
Bike runs smoother at low revs and to my educated backside feels slightly more powerful all the way to the redline . Can't remember where I found all the connections as I was really struggling to get my hands in ( glove size usually XL ) . I do remember having to go back in after switching the bike on because I'd missed one connection . Just double check everything don't get impatient ( my problem ) check you tube for fitting videos .
Discussion Starter #15
Update:It is installed and my bike is already running soo smooth! Quick question though, Do I have to enable the auto adaptive feature via the software, or is working out of the box? Also is there a need to see a tuner and update the base map?
I hope you don't have to do anything else apart from plug it in because I haven't . Four months on and not blown up yet , rarely get up near the red line unless I've found someone to play with .
Discussion Starter #17
Okay. Do you use the software at all?
Leo Vince makes a great CAT removal I have one on my Svart 401. its for the 390 and fit like a OJ glove!! more power did not lean the bike out much makes 44hp on the Dyno at the rear wheel.
sorry thought I was in CAT post.. my bad
As I recall OJs glove didn’t fit too well. Here is to hoping you meant that the cat eliminator pipe fits better than the glove did??
Reactions: Abitibi
1 - 20 of 20 Posts
