1 - 19 of 19 Posts
Hey guys,
My passenger seat keeps popping up and I can't see anything or any reason why this is happening. It's not locking down for some reason. Looks like I am gonna have to have a shop look at it. I almost lost the seat one day. When I got home the passenger seat was pretty much just laying there over the hole totally loose and not connected or locked down.
Any ideas or suggestions would be appreciated!
Jeff
I think there is a spring which keeps the closing mechanism closed. It should be easy to check if the spring is there and if it only opens if you turn the key.
you might also find the 'catch' area could be slightly rounded from use which might allow it to slip out
OK thank you! This bike is like new....it is 2019 with 1300 miles....never really took back seat off accept when I put a tail tidy fender eliminator on.
have a look around all the parts you moved or changed and make sure everything is seated correctly and no new parts are causing an obstruction
Should be a bit of grease on the pin that protrudes down into the locking latch.
After all is checked out and you reinstall the seat, press really hard directly from above the seat pin area and you should hear an audible sound when the catch engages the pin.
I have cowl on the back of mine, don't know if this make a difference but the seat does not always just pop back in I find using the key to lock instead of pushing down and hoping its pops in place. basically turn the key like you would when unlocking, it push down on seat while turning key to lock it again works for me,
I have the cowl too. Was trying to make it easy for the OP. Try both methods to get it latched.
Easy enough to check to see if it worked, just pull up
Hi Folks,
When I first got my 390 Duke, the passenger seat was very hard to lock down. I filed off a very small amount off of the locking pin so that the latch would catch easier. Solved the problem.
Craig
Discussion Starter #12
Hey guys,
Jeff
OK I am not seeing anything that can be causing this. It just looks like the pin/hook is not locking good. The spring seems to be working good. I don't know....sucks you cannot see down in there when the seat is pushed down into place. No wires are in the way
ok another thing you can do to give you an indication of what might be happening,
colour in the locking mechanism and the seat post with paint or marker pen etc. all around where the two parts meet, then fit the seat and release it a few times so that the coloured in parts get the colour worn off, it should tell you how they meet or if they are out of line
Jeff,
It's because the locking pin is not going down far enough for the lock to spring into place. If you file about 1/8th of an inch out of the bottom of the slot on the pin it will engage. Sorry if I wasn't clear enough in my explanation earlier.
Craig
Discussion Starter #15
Jeff,
Craig
Thank You Craig! Very grateful....if this is the problem and your solution works I have to wonder why such a problem exists...something bent or not formed right in manufacturing maybe....in any case I will give this a try and if it does not work out for me I will let the KTM shop locally look into it.
Discussion Starter #16
Hi Folks,
Craig
Craig, I never saw this response until tonight...I'm sorry you never heard a reply from me on this.
Discussion Starter #17
I appreciate all the time you have spent on this and want to thank you for your suggestions....
This happened on my new 2019 as well. Dealer had to swap the locking mechanism from another bike. I bet fling the slot would work. I couldn't see another reason. The locking mechanism tab was a little bit bent and that was all it took to not engage the seat post
Mine’s similar.
I dismantled the mechanism and it seemed fine, and there are no adjustments.
I found that if you install the seat, then thump the seat above the locking mechanism with your fist, the mechanism locks.
1 - 19 of 19 Posts
