1 - 4 of 4 Posts
I own a KTM Duke 390 2018, full stock. Starting this discussion as I want to know if anybody swapped their duke 390 rear shock with duke 250s?
I weigh 62 kilos and KTM duke 390 is an absolute snack on the track. But as the suspension is non-adjustable(tried preload's last setting also) and I'm not heavy, and as India is a country where you sometimes find good roads between rubble and gutters, I find 390's suspension to be super stiff for the streets! I can feel every pebble under my ass.
I rode my friend's duke 250 and found a lot of difference and found it to be very comfortable for Indian streets. I thought the swap mightwork as I can adjust 250 duke preload and make it stiffer for track days.
THOUGHTS? ADVISE?
snack on the track...hahah.
have you tried setting the preload on the bike first? the rears can be adjust on a clicking dial, try dialing it down if you find it too stiff.
Yes, as I mentioned, I currently dialled it down to the last level, it only made the seat height higher but no difference in comfort and is still stiff for my weight.
Not sure if the 250 rear is different from the 390. I recently replaced the rear of my 200 (2012) with my 390 as I put an Öhlins on that 1.
In all honesty, the stiffness feels the same I only think the rebound is better on the (2015) 390 shock.
Can't really imaging the 250 being that much different from the 390. I weigh 74kg.
1 - 4 of 4 Posts
