1 - 2 of 2 Posts
Hey everyone,
2016, wifes bike.
installed the Rizoma 3 wire, the indicators are working as indicators.
however there is little to no info on how to wire the 3rd "running light" wire
I heard rumour of tapping in to the low beam...but what the positive? no need for negative?
is there a smarter place to tap in to on the head unit, or main wire loom? as opposed to splicing in to the low beam bulb area?
thank you!
I just installed a similar 3 wire signal on my 2018. I tapped the wire going to the LED outer ring, however could have just as easily used the low beam depending on desired behavior. Instead of cutting and soldering the harness, I used a positap connector.
You do not need to tap any negative because it uses the turn signal negative wire.
I can confirm that the running light turns on when key is on and appropriate side turns off when blinker is turned on using this method.
1 - 2 of 2 Posts
