1 - 1 of 1 Posts
2015 390 Duke
Hi everyone! So I recently got a 2015 390 Duke and had opened up the headlight dome looking for the ACC connectors to connect my phone charger to. I didn't find them (mine doesn't have the ACC circuit) but found an odd little plug which had the ends shorted with a connector. Please see the attached image. Does anybody know what this is? Un-shorting it didn't seem to make any noticeable difference. I measured the voltage across the wires with the shorting plug removed and it was a little below the normal system voltage, around 10V with the engine off and 12V with the engine running. Cutting off the ignition would unpower this circuit.
Curious to know this is. Looks like a switch of some kind that is hard-wired on.
Thanks!
1 - 1 of 1 Posts
