1 - 5 of 5 Posts
Does anyone have the spark plug wrench that came with the tool kit? Mine broke while swapping plugs and is now useless and since that is the only wrench that fits down I the plug tunnel I am stuck. I will even buy the entire tool kit or whatever is left of it (since those little tools get lost easily) if you want to ditch it.
Why not buy a 14mm spark plug socket and a 3/8" wrench?
I've got 1 from the Blue Point brand (similar to Snap-on) works great.
Another advantage is it holds the plug magnetically instead of the horrible rubber ring in the OEM socket.
I couldn't get a deep well craftsman socket down there, and had read that the tube is so narrow that only the tool kit wrench worked. I'll try a cheap-o gas station socket (they tend to have thinner walls) and see if that works.
Thin-walled 14mm spark-plug sockets from Snap-On, Blue Point, Facom, Stahlwille and more?
1 - 5 of 5 Posts
