41 - 55 of 55 Posts
I have a feeling the Dealer is still giving lip service. Just my guess
Discussion Starter #44
I got the diagnosis from the dealer that the engine is blown. They're working with KTM for a replacement. 2,388 miles on the clock. At this point, I'll be looking at selling it when I get it back and moving on. I'm not really a fan at this point.
Bike just dies alongside the road (if I remember correctly) and it’s a blown engine??? What blew??? I mean besides the dealer. No noise(s) leading up to this ‘blown’ engine?
Discussion Starter #47
No noises that I noticed. Seemed to be running fine up until that point. I have no idea what exactly blew, but they said there's no compression. Won't know that until/unless they open up the engine. If the shop is busy enough, they may not even bother doing that, they may just swap it with the one KTM sends them then crate the blown one up and send it back.
Wow, that sucks. Sorry to hear.
Wow. That’s a big bummer.
No compression without any noises leads me to believe it is in the top end of the engine vs the bottom end.
Reactions: Whiskey
Dropped a valve? incorrectly adjusted exhaust valves from the factory seems to be an issue with some of these bikes.
My suspicion since there was no apparent noise with the engine giving up: burnt valve(s) and/or valve seat(s)
Discussion Starter #53
Well, that took quite a while, but apparently she's back to running. I got a call from the shop yesterday letting me know it was ready, but I was out of town and they're closed on Sunday and Monday, so I won't be able to pick it up until Tuesday.
The guy told me when he called that they found the root cause of the top end failure. Apparently there was a small piece of plastic that got into the engine and clogged up the oil injector, which starved the top end of oil and caused the failure.
Since the engine has never been worked on it obviously came from the factory that way. I haven't seen the plastic, but he said it looked foreign, not something inside the engine that broke loose.
Chalk one up to crappy QA at the KTM factory. I'll try to get more specifics on Tuesday and share what I learn.
Reactions: varroa
Glad that’s sorted. I’m not a big fan of the sealant they’ve used between the engine cases for just this reason. I’ve seen the top end die on bikes before because someone thought that silicone was a good way to seal up the rocker cover.
For a piece of plastic to get into the oiling system it has to get by one of two screens and a filter, so it did not get into the oiling system but was probably assembled at the factory with the foreign object in place.
Glad to see they finally sorted you out.
41 - 55 of 55 Posts
