1 - 3 of 3 Posts
· Read Only
Hi all,
When I got the 2013 Duke 390 from the previous owner, the idle was set very high for some reason.. 2000-2100 rpm? The throttle had a bit of cable play which is good so I just unscrewed the idle screw on the throttle body a bit to get the rpm down to ~1500 rpm
However with the cold weather I noticed more irregular idles and engine stalled every now an then so I've increased the air intake a bit but is the any proper guide on how to make this adjustment correctly? thanks
Auto part Composite material Metal Event Machine
1 - 3 of 3 Posts
