As title I am going to undertake this conversion very shortly. I did find a thread originally going this site regarding someone attempting this conversion but am unable to find it now. I have motor,ECU, Header pipe and air box. A new drive train will also be purchased as the sprockets are different. From what I have read the conversion should be straight forward (No conversion is ever straight forward).
Has anyone completed this conversion that could highlight some issues I may encounter? Any help would be greatly appropriated before I start.
Thanks in advance
Hi Powell, I did the conversion and here is the list of the parts you will need, and the price from KTM in Italy:
-Used Engine - From EUR 500 to 1.000,00;
-ECU - EUR 396,90 (or map yours with Duke's 390);
-Complete Throttle Body - EUR 481,74;
-Muffler Cpl. - EUR 100,80;
-Muffler Clamp - EUR 10,80;
-Exhaust Flange Gasket - EUR 6,72;
-AirBox - EUR 97,68;
-Ignition Coil - EUR 30,00;
-Upper Engine Support Left and Right - EUR 48,48;
-Radiator Support Left and Right - EUR 4,68;
-Silent Block M6 - EUR 6,84;
-Hex Bolt M6x8 CH.10 - EUR 2,40;
-Hex Bolt M6x10 CH.10 - EUR 4,80;
-Sprocket Cover - EUR 7,38;
-Clipnut M6 - EUR 1,68;
-Belly Pan - EUR 60,48;
-Belly Pan Mtg Top - EUR 6,72;
-Belly Pan Mtg Rear - EUR 6,72;
-Belly Pan Mtg Middle - EUR 6,72;
-Hex Bolt M6x14 CH.8 - EUR 2,40;
-Hex Bolt M6x20 CH.10 - EUR 2,40;
-Hex Bolt M6x12x3 KTM Special - EUR 6,12;
-Hex Bolt M5x16 Cheese-Head KTM - EUR 1,68;
-Clutch Cable - EUR 20,16;
-Complete Exhaust Arrow - EUR 352,00;
-Filter K&N - EUR 45,00;
-Shipping Costs - EUR 20,00;
In my case:
My base was a 2016 duke with ABS, and it already has the same front brake used on Duke 390...
I just bought the engine with the exhaust coupler, and gaskets, air-box, throttle body, ignition coil and ECU for € 500,00, from a Duke 390 with the frame damaged and 3.000 kilometres on the clock, and everything else I have to buy.
You can see pictures here:
ttima con il motore 125 per Neo-Patentato. Sei pratico a guidare e vuoi più potenza, nessun problema. Installa il KIT del motore 390, che è compreso nel prezzo, e la moto da 15CV dichiarati dal costruttore, passa a 44CV. KIT 390 comprende: -Motore
www.subito.it
Best regards and good luck, in your project.
Banion Scheffer
